Looks like ebay didi2ice4m3 wrote:who told you that's a Nismo intake?
Just because it has a name on it does not make it real. There is a real problem with cheaply made counterfeit parts being dumped especially on ebay. They are currently working on legislation to outlaw this crap and allow for its seizure and destruction. Regardless I think I just blocked that tube off with a bolt and hose clamp on my s13. I think it is for the air pump for smog? I am not fully sure.young-gunn wrote:I actually bought it out of a shop in California somewhere. It has NISMO right on the filter, so the filter obviously is, maybe the tube part isn't Nismo, but the filter at least is.\
that's a possibility, maybe ... you should take pics, i'm having a hard time trying to visualize the "two bends"young-gunn wrote:ok, well this is wierd, My cold air intake doesnt fit! It's got ttwo bends before the actual intake, instead of the one, like the original one does. Has anyone else seen this problem? I have no clue why it is like this, could they may have shipped me one for a SOHC engine by accident?
From the pic up top, it looks right. 99% of anything you find on ebay if you type in NISMO, HKS, Greddy etc isnt real.. and to see what stuff sold at a shop just pisses me off. Theres nothing wrong with an intake like you bought, kinda hard to screw that up I think. As for it not fitting, use the double sized coupler instead of the throttle body boot. it should have an extension metal piece to bolt up to your passenger radiator support. make sure you connect the vacuum hoses, one goes to the throttle body, one goes to the valve cover and one goes up to the top right of the throttle body. the hose that was connected under your old intake on the passenger size is a resonator, you dont need to clamp it off, just remove it. Im guessing the maf adapter plate has a bung on it, youll need to cut it off or go to like autozone and get one with a plug (~$10) to use the filter on.young-gunn wrote:ok, well this is wierd, My cold air intake doesnt fit! It's got ttwo bends before the actual intake, instead of the one, like the original one does. Has anyone else seen this problem? I have no clue why it is like this, could they may have shipped me one for a SOHC engine by accident?
Can you take a picture of yours so I see what to do here? I am totally lost on this one, the rad connecter thing does not line up with the rad, because of the fan shroud being in the way.popogto wrote:thats not nismo for sure. i got the same thing. the pipe will fit but has no support. so zip tie it and you may need to take off the fan shield but i strongly advise against it. after that. all the pipes are just like znelson kindly drew.
