bender24k »
https://forums.nicoclub.com/bender24k-u124818.html
Fri Jul 02, 2010 10:36 am
I have always found that jumping timing is a sensor or wiring to a sensor problem. Start with setting the TPS, and then move it's wiring around while the engine is running and watch the timing to see if the jumping around is affected. Do the same thing for the knock sensor wiring, top engine harness wiring & grounds and finally the main ECU plug / wiring.
No matter what other problems you find, your statement about not being able to give it full throttle without breaking up sounds like a boost leak to me. Boost leaks can be very frustrating to find - I have seen guys use "testers" multiple times then give up and remove all the piping just to find a tear in a coupling.
Yank on the piping hard, check each and every coupling for splits, verify the pipe alignment is not leaving a gap that can burp air out, make sure your BOV is not leaking. If you are using a tester, make sure your piping holds 15 psi on your boost gauge for more than just a few seconds.
Good luck!
-Jeff
