I need your help. I just bought a used 98 240sx SE this last Monday. Everything has been going just fine until today. The car is damn near immaculate in terms of cleanliness, so I was just putting loom around some of the hoses and lines to make the engine look even better. After I got done with that, I was getting ready to go home...and I wanted to try the "shiftkit" mod again that I read on this board (for the automatic cars). So I unplugged the resistor while the car was off. I turned the car on, walked away for a minute and when I came back, my mom was behind the wheel with a grin on her face like she wanted to take it for a test drive. She was reving the engine just a little bit, but nothing major. When I went over to tell her that the car was going to shift harder, I looked inside at the gauge display and noticed the dreaded "service engine soon" light. I checked over anything that I could have bumped when putting the wire loom on, I plugged the resistor back in, check the oil (ok), and turned the car off. The light still wont shut off. When I tried the resistor trick the other night, I had no problems with it. The only difference is that when I did it the first time, the car was still running while I unhooked and rehooked it back up. This time the car was off, I unhooked it....and I have a service engine soon light. Could this be the culprit, and if it is....what can I do to reset it? Unhook the battery for a while? I know with my Cavalier....if the car saw anything unusual (like when I left the AIT sensor out of the intake tube...it tripped a light, but all you had to do to clear it was to plug in the sensor and do a cold restart on the car 3 times. Then the car would reset itself. Worked like a charm.
Is there anything like that with the Nissans? Sorry if I seem like a twit, Im just trying to get used to a different car.
PS- Do these cars have any notorious problems that I should be looking/listening for? I swear after that light came on and I started to really listen to things, that I could hear something under the valve cover. No knocking or anything. But just a noise that I dont "think" I heard before. Maybe Im just hearing things now.
*worried to death that my new baby is broke*
Please help,Brad
