racerSXtreme240 »
https://forums.nicoclub.com/racersxtreme240-u14328.html
Mon Mar 08, 2004 10:19 am
i am currently building a KA race engine for my 240 project, i was originally gonna build a powerhouse NA but money and time have put a damper on that, so its now going turbo... but when i had decided to delve into my NA project i invested in a set of HC forged pistons which will not be used in my proect car for obvious reasons, but i am rebuilding my daily driver 240 as we speak and it occured to me that with my cams and those pistons i could possibly see a decent increase in power, i have read all the piston threads on here but none of them touched on my main concern, which is: If i install these pistons will there be any ECU problems to worry about?.. i seen a post on one of the other threads that a couple of guys were running 11.5-1 with JWT ECU, which i didnt plan to get, so i need to know if i can run 11.5-1 or 11.7-1 compression with a stock ecu and without probs... im not worried about any kind of mechanical failure, the engine is a fresh rebuild with performance gaskets, and the block only has about 50k on it, ive already got I/H/catless E, ported polished and port matched heads an intake, so it is going to be a fairly clean flowing engine, i also still have the butterflies in my intake due to my 248-248 cams, it was the only way i could come up with to save a little of my bottom end, and i must say that i cant tell an extreme difference between them on low end power... anyway, sorry for the novel of a post, i tend to over elaborate on questions, any help would be appreciated... thanks
