Need info urgently please! Sentra distributor in G20?
yyz
Car: G20t
Hi guys, I need help urgently. I need to change the distributor on my '00 G20t, and I found an auto-recycler place that has a pulled part from a '01 Sentra. They said it will work on my car, are they correct?
nametakennow
Car: '06 MINI Cooper S
If the Sentra had the 2.0, yes.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
more importantly, you need an obdII distributor, which the 01 sentra is, so yes it will work. the distributor you need has an internal coil.
yyz
Car: G20t
Thanks for the info guys! I got the distributor and put it in. I was told I need to move it around to get the timing right. I didn't know that and I just had the bolt in the middle. Anyone know the best position for the best performance? I don't have a timing gun, btw... thanks again for your help!
Raxephon
Car: '04 RX8...for the moment...
yyz wrote:Thanks for the info guys! I got the distributor and put it in. I was told I need to move it around to get the timing right. I didn't know that and I just had the bolt in the middle. Anyone know the best position for the best performance? I don't have a timing gun, btw... thanks again for your help!
Find someone with a timing light or rent one some where.
Don't do it by ear, you could set it farther off from where you want to be than you realize.
