centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Feb 29, 2016 1:25 pm
Hello. Are you getting Richard's Good Parts kit? Do you have the kit already or are you trying to anticipate it before the bits arrive? I read that it has adapters to bolt your Triumph driveshafts to the R200 differential. I'm a bit unlcear on what you'd be doing with the Q45 driveshafts and figure you'd want/ need to use the stock Triumph ones. I figure you'd just use those adapters. Are you putting in a full subframe or just the differential?
I can measure my CV joints for you tonight, but looking at photos of q45 and 240sx shafts side by side (yeah, we photo stuff like that to discuss differential options here), they all apear to have the same diameters within a quarter inch or so. Certainly not the inch plus smaller you're hoping for.
Most of the shafts have different lengths or bolt patterns, but simlar diameters. Perhaps you need the differential output shafts with a different bolt pattern? Those are something people here buy sometimes and have different lengths depending on the internals of the differential.
What bolt pattern do you have on your R200 diff and on your Triumph driveshafts? I think you want the 5 bolt pattern for your diff (star shaped), not the 6 bolt pattern (3 pairs of bolts in triangle shape). Is that the issue?
