need info on sr20det engine swap
pleasehelp84
hey you guys, im new to this whole 240sx, sr20det engine swap thing. i have a couple of questions1. where can i get a good quality engine without being ripped off.2. can engine swap be completed in less than a week.3. what parts will i need if im planing to do the swap into a 1990-1993 240sx?4. and can i use this as a daily driver?
Silvia007
Car: 93 Nissan 240SX SE Fastback
1. http://www.phase2motortrend.com, http://www.srswap.com.2. It can be done in 1 day.3. Buy front clip, this way you won't need anything extra. srswaps comes complete so you don't have to worry. Otherwise, probably FMIC, BOV, hotpipe, clutch.4. Yes SR is very streetable and is great for a daily driver. Just make sure to get ACT's organic disk clutches. No pucks!!! I have one and I hate it, wayyyyyyy to grippy.
LSB_11
Car: cars, motorcycles, sports, flying,
or you could get a haltech, and have no support from anyone, and have a shop who doesnt really now nissans get it done in 6 months. *alittle bitter*. i think i would have better off doing it your route, get the clip, do it yourself, then upgrade things after its good and running.
Silvia007
Oh, DO NOT forget the downpipe, I did.
pleasehelp84
what exactly does the down oioe do? does it take the place of the catalyic converter? and if it does will the car pass emmissions?
danielmid
Car: Currently a 99 Frontier - FOR SALE
No. Downpipe is turbo-->cat. Get rid of the cat, get a test pipe, and a full exhaust. Most emissions will pass a turbo car, they run hotter so if your car is running right, it should pass. At least around here they do.
Daniel
nismostate
Car: all sorts of motorsports
i would recommend changing most of your stock seals too; oil, pan, rear, front, transmission rear seal. those are common places to leak on sr's and it's a PAIN in the *** to change while the motor is sitting in the car. you might not pass emission w/ a straight pipe but all i did was bolt on the stock KA cat before i went
