Need Info of the S15 T28 or GT2871R, for upgrade...
achidrift
Car: Nissan 240sx 1991 (Sil80) - SR20DET
Firts, i have a SR20DET RedTop Stock T25...
Now i'm having problems with the turbo because is passing some oil, so an uncle tell's me that in a near future i will have to changed. So i look online and see this two turbos upgrades, my question are: 1-Saving Money2-Which is more effective?3-What pieces i will have to buy to install the turbo in my SR20DET? For the T28 and the GT2871R
Is someone have more opinions i will be glad to read it...
Next turbo upgrade, S15 T28 or GT2871R???
Sr20S13Det
Car: 1991 240SX Redtop SR, 1989 240SX Parts Car, 2000 Ford Ranger (DD)
What are your goals for power and future mods?
duffman1278
Car: 89 240sx Hatch, the wildcats!
This is an OLD TOPIC with very different opinions and routes. Stop trying to get spoon fed. The answers will vary, it's up to you to do the research and decide which way you'd like to go based off your budget, goals, etc.
And PLEASE correct some of your spelling and sentence structure.
achidrift
And PLEASE correct some of your spelling and sentence structure.[/QUOTE]
jaja, i'm still learning english...
achidrift
the next time i will use the search buttom before creating a new topic....
sorry
duffman1278
No sweat. Yes just make sure to use the search button and google.
achidrift
well, to the point...
If i buy the T28, i also have to buy this parts for upgrade..
S14/S15 Turbo Oil Return HoseS14/S15 SR20 Turbo Oil Return TubeS14/S15 Turbo Outlet PipeS14/S15 Turbo Inlet PipeOEM S14/S15 Turbo Outlet GasketCircuit Sports S13 SR20DET Turbo Lines (Bottom Mount)
Extras:Tomei Exhaust (Turbo) Manifold for Nissan SR20DET Silvia S13/S14/S15HKS S15 ActuatorZ32 MAF Sensor
My Question, if i buy the GT2871r, i will have to buy those parts for the upgrade?
domiballa
Car: 1993 s13 hatch
yes you would. but the actuator is only if you want.. and on top of the maf you'll need injectors and a tune to run it safely.. boosting a 2871r on a stock sr is dangerous. or if your broke just buy another t25 and save up
achidrift
but with the T28 i also have to buy injectors???
schanne
Car: 93 Hatch-Sr20
Yes. Either way you will have to upgrade injectors and have it tuned. Also with the parts you have listed. It's not as simple as just plug and play like your thinking. Get the right parts and have it tuned and you will be very happy!Goodluck
S14toRPS13
I've seen S13 SR's run a S15 turbo with no tune, no upgraded injectors, and on 16 psi. I wouldn't recommend it, but I've seen it done. The car's been running for about 4 or 5 years now. It's dd at 12 psi though.
Ninjamasta
achidrift wrote:well, to the point...
You don't need that MAF sensor yet but if you could find a good deal get it.As for HKS Actuator, don't get it until you have FMIC, 450cc injectors, tuned ECU, and wideband. These parts are needed before going 14lbs of boost.
achidrift wrote:but with the T28 i also have to buy injectors???
Unless you are running more than 12lbs of boost, yes.
achidrift
i think i will go for GT2871r, but i need to ask you, which are the essentials parts, for this upgrade?? and recommendations...
schanne
Car: 93 Hatch-Sr20
Search that and you will see the build threads and it will answer all your questions. gt2871r is a nice turbo and with the correct supporting mods you can push some good hp. I think codyace has that turbo and puts 399hp with some other mods. Searh my friend
