Need Immediate Help removing tail lights!!!
abice
Car: 2009 Infiniti G37
I'm having some trouble removing my tail lights im sending them out to get Painted, I've removed the carpet surrounding the tailights in the trunk and have unscrewed all three screws on each tail light side. I would think the would just pop right off but it seems they are still attach on the sides. Anyone done this before and know exactly what's still holding them in place?
zozoka1212
Car: 08 Infiniti G35x
Never actually did it so not much of a help here. Have you tried to remove the plastic cover when you open the trunk. There might be another screw.
abice
yeah i did that the trunk is completely cleared out and the carpet is taken out it's basically just the metal on the inside of the trunk there's no other visible screws so i don't know why it isnt popping out
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
I just looked it up on Alldata. It is an online service manual. It shows removing 3 nuts. Then pulling assembly rearward to remove from vech.
It also states that the sealing packing where the studs go throught the body MUST be replaced.
abice
yeah i see the two sealing buttons where the seal needs to be broken in order to remove the the tail light housings, but what is the way to break the seal my brother said take a wrench and turn it maybe, but when I break it and remove the tail lights where do I by new ones to replace it or should I just fill in the holes where the sealers were and not worry about installing them back in?
CYO44Baseball32
Car: G37S 6MT
Your doing it right, you just gotta pull hard, don't be scared
abice
I got it thanks for the help guys also dealership helped me out today I was babying it because I didnt want to hurt them lol but its all good
