need idea on mods
paco240
Car: sports and racing
i have a 93 240 and i am needing some ideas on some mods that i can do....i would like to order my body kit in the next week or so and i need to be able to spend some money under the hood while i am at it so any suggestions would be a help....i am not wanting to spend a ton of money just yet so cheaper ones are better.
240marcuSX
Car: E34 525i
E46 M3
then decide what youre doing with the car?(which motor?, drag racing? drifting? auto-x?)
then pic the parts that you like, but make sure you dont get ripped off.
most people do intake/exhaust first. or suspension
240marcuSX
Car: E34 525i
E46 M3
first fix broke stuff.
then pic the parts, but make sure you dont get ripped off.
ch1873857
yeah do intake, exhaust, headers, suspension, brakes, tires then start saving for turbo
yeswepromise
do all exterior stuff so that you can do well at car shows.then start on the interior so you will win car showsthen dress up the motor so you will own car shows.
quiksilvia
Car: 95 s14 se
i would go backwards ywp. get it fast first, so u have a sleeper more or less, then do interior-function only, dont paint door panels! then get a kit and through some susp work in there somewhere
corn322
Car: 1993 240sx
get those extending exhaust pipes I heard about
paco240
ok now that i know all that stuff what kind of headers and intake would you suggest....and if you do know what kind you would suggest then try to give me the price range on it....there is no place around here that even works on my car let alone sells anything for it so i will have to go and order it all off of the net so i need to have a range to know what i am gettin into ....i want to be able to race it...i already do a lil street racing and am pretty succesful at it with the factory stuff....but i need that lil bit of an edge and since i cant yet afford the turbos i need some easy stuff
GroundZero
well seeing as you don't know what direction your going with the car i'd stick to mods that you can use in almost any setup
for an intake you can jump on ebay, you can get a cone filter and maf adapter for between 10-20 dollars
if your planning on turbo charging the car or swapping engines than i wouldn't bother buying headers now seeing as you'll have to replace/sell them later
a good cat back exhaust is always a plus, you can get a full exhaust or you can save money and just buy a muffler and get custom 3" exhaust pipe made for your car(same thing just not name brand and mass produced, most times custom is best)
an 18 psi nismo radiator cap will raise your cooling effect in turn protecting your engine and helping power production you can get one for $30 on ebay
some websites of interest:
http://www.optauto.com http://www.nopionline.com http://www.cyberauto.com http://www.wholesalehyperformance.com http://www.importperformanceparts.net http://www.hotshot.com http://www.240sx.org http://www.projectsilvia.com
thats bout all i can think of right now, check out those websites and think about it, make sure to plan ahead, don't waste money on mods that you won't need later. good luck
GroundZero
oh i forgot about cams, you can get alot of power out of the right size cams
jdmfreak
What are some good yet affordable cams?
theronin
its all about a drift kit man... get a drift kit those are the awesomest. drift kits are tyte!
chmercer
get a weld on muffler and some GTR badges to go with the drift kit, ronin knows what hes talking about. JDM TYTE YOOOOOOOOOOO
jdmfreak
Oh yea I heard that a drift kit, along with a weld on muffler, and GTR badges should give me about 400 hp right?
Seriously though, what companies offer some good cams for descent money. I dont want nothin cheaply made cuz thats just a waste of money. Please no APC ****.
chmercer
for what motor? and jun and hks make good cams but i bet they are expensive
GroundZero
Nismo makes some good cams for the ka and the sr
pball
jim wolf and PDM cams are both insanely good for the ka, but you really need an ECU to get the best performance gain from them.
GroundZero
yeah and since your workin on the head anyway why not get a good port n polish job done and build your valve train
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
as for intake, ive heard ppl that did the homemade intake on 240sx.org like it a lot, its cheap and effective, from what i heard, havent tried it yet
pball
you dont need a polish until you have a seriously tuned NA engine - high compression pistons and heads, conrods, bearings, valves, things like that. otherwise its just a waste of $900.
4felix20
Car: Emerald Blue S14
what kind of money are you willing to spend on the engine performance issue? instead of getting a body kit, you could afford some turbo power. there's really not much that will boost our naturally aspirated engine. you can get small upgrades that will squeeze the last drops of power from it, but that's all you are really doing....squeezing that last bit, not actually adding power.
theronin
im tellin ya... drift kit!
jdmfreak
Yea I finally the light and took ronin's drift kit advice. Let me tell you the honeys were all over me. I noticed a substancial increase in power when I added all the badges, stickers, and a fart can. From then on its been gravy.
theronin
yeah... listen to fanboy jdmfreak, drift kits are the 1337
jdmfreak
4felix20 I suggest that you buy one. It would change your life as it has changed mine. Trust me you cant go wrong with that drift kit. It works wonders.
pyite
It's dat WOO-WOOOOO!
