Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Jun 02, 2008 5:35 am
He did answer your question. There are no special parts you can buy that would make the TT hubs work on your 240 spindle.
Your options are (and if you've really done research, you would know this already) s14 front hubs and spindles (including LCA ball joint and strut bolts), or aftermarket conversion hubs.
And before you ask about the rears, they won't work either. The TT uses a bigger rear axle, so the 240 axles will just rattle around loosely in the hub.
