Need help with Z32 maf in a S14 KA-T, please!
Turbo Nismo
Car: S14 powered by KA-T
Hi, I installed a 300zx Z32 maf in my nissan S14 KA-T, with 95 stock ECU and a safc II. I put the cables just like the Z32 installation diagram says, Like this:
And out putted the safc II in in 2 and out in 5, the car starts, and runs fine in low throtel but when I try to boost him in high throtel it rev's in 4 000 rpms and it only boost's like 2 - 3 psi and it wont go further, but in low throtel I can go to 6 500 rpms without problems. What could it be? Do I need to put something else in the safc II to make it work?
My set ups are :- 370cc sr injectors-Z32 maf-Safc II-Garett T3/T4-ARP head studs-Cometic Gasket-Forged Eagle rods-Nippon pistons ( Not forged)-Walbro fuel pump-38mm ebay waste gate-Ebay turbo manifold-FMIC-Malpassi fuel pressure regulator 1.1
And I'm running @ low boost 6-8 psi
I need help please!Thanks.
Turbo Nismo
Can anyone help me please?
kouki_hmongster
Car: Want 97 kouki
make sure you dont have any boost leak. what's your vac reading at? usually bad maf wont let you rev to a certain point. i need to double check your diagram for maf wiring. also your afc 2in 5out is right.
EDIt: how far is your maf from your turbo? should be at least 12inches. unless if you're running blow through.
Modified by kouki_hmongster at 11:49 AM 2/5/2009
Modified by kouki_hmongster at 11:55 AM 2/5/2009
Turbo Nismo
kouki_hmongster wrote:make sure you dont have any boost leak. what's your vac reading at? usually bad maf wont let you rev to a certain point. i need to double check your diagram for maf wiring. also your afc 2in 5out is right.
Modified by kouki_hmongster at 11:49 AM 2/5/2009[/i
The maf is 10 inches far from the turbo.
Turbo Nismo
Problem solved it was one of the intercooler pipins that cas disconnected.
