numbernobody »
https://forums.nicoclub.com/numbernobody-u159931.html
Tue Jul 13, 2010 11:48 pm
Hey, beside the plug, there should be two other wires. A ground held on by a small bolt, and another that sits on a post and is held down by a nut. This one goes back to the battery to charge it. Also, there is supposed to be an insulator (maybe ceramic or rubber) on that post and if it's messed up like mine was, you'll be shorting out on the alternator case. Could that be it? Just bad wiring?
Good luck
