need help with xenon 01 headlights
timderiksen
Car: 1998 Q45t-wanna be cima
i put 01 headlight on my 98qt and the low beam hid dont seem to be very bright. Is there some kind of reducer or something? if so can would i be able to by pass it to make my low beams hella brighter
timderiksen
does anyone know what im talking about or do need to take a picture??i would like to have my lowbeam brighter
Ludeaem
Car: 2000 Infiniti Q45 AE
id take a pic. may need finer adjusting for the beam. you gotta remember this is a reflector housing HID and not a projector so light output won't be a generous
qship96
Car: 1996 Infiniti Q45
Might help if you proof-read your question before you post, so it is easy to understand what you are trying to convey.
timderiksen
here what im talkin about. what is the box for???
qship96
The box appears to be the ballast for the HID lighting system- a critical, must have component of HID style lighting systems. The function of the ballast is to step up the vehicles 12 volt electrical output to a much higher voltage to ignite and run a arc {HID} type lamp. You may have a faulty ballast if you are not getting a brightly lit bulb.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
You have to be joking. You took the time to install HID headlights but removed the ballasts? If you are running 12 volts through HID bulbs then you are about 34,988 volts short!
-A
timderiksen
that was from my old headlight that got the lenses broken. Its no the ballast, the ballast goes underneath the headlight it self. it has to be some kind of regulator but im not sure. Thats why im asking what it is
bullittandy
Sorry, but your post remains unclear. does your headlgiht work? what are you trying to solve? etc etc etc etc
timderiksen
im trying to figure out WHAT that is!!!!? i have new headlights now all new ballast and everything. that came off my old headlight so does anyone know what it is!!!!????????
