need help with wiring
goj_cloud
you kow how the fr sport tutorial says cut and extend the o2 connector, the turorial says its brown/yellow,white,and brown. mine is black,white,orange
AmoebAssassin
Car: 1991 Base fastback 5spd, black
It always sucks when your wire colors don't match up to the guides, but since you aren't splicing anything, wire color is insignificant. Cut all three wires, get three equal lengths of wire. Solder in each length of wire between the two cut ends of each wire, making absolutely sure the black goes to black, the white goes to white, and the orange goes to orange.
PS - Are you sure you're splicing the correct connector? Lots of connectors look similar on the SR harness and it's not uncommon that someone will goof up and grab the wrong connector.
