need help with wheels ASAP!
All things Altima Coupe.
T00Ezy
Car: 2012 Nissan Altima Coupe 2.5
Hey guys, i need some assistance! I just ordered a new set of a wheels but i forgot to check if my car can even fit a +30 offset... I got mb battle wheels +30 offsets. Im looking to wrap them in 225/45/18. I'll be dropping my car on eibachs right after. am i going to rub or will i sit flushed at the stock fender? will i rub inside in the front as well or is the wheel well going to be big enough?
kevin13nor
Car: 2012 Altima Coupe
Fit with no mods to fender. Enjoy.
T00Ezy
answered all my questions thanks kev :)
T00Ezy
kevin if you dont mind, what about 225/50/18? would that fit without a problem?
kevin13nor
What are your wheel specs? 18x????? +30. Let me know your width. But if anything a 50 series tire is a bit too much.... too tall. It's going to look funky on a 18
SanoSuKe
Not only it will look funky, but also it might bubble up. It's just like stretching tires, it gets dangerous at one point. Same for too much tire.
T00Ezy
alright i guess 225/50/18 are out of the story haha the wheels are 18x8 +30. i was just thinking about the 50 but if its not going to be comprable it would be a waste. ill stick with 225/45/18.
BamaCoupe
Car: 2011 G37 Coupe
You need to go 235/45/18 to match your OEM O.D. which will keep your speedometer and odometer correct. The 225's are cheaper, but it's going to make your odometer roll over faster. BTW I'm on 235/45r18's with 18x8 +33mm / 18x8.5 +30 offset on eibach's; you'll be good.
T00Ezy
is that why it seems abit off? im using 225/40/18 right now lmao feel like im going 20 when it says 40. wheels came in today, going to get em installed monday!
BamaCoupe
Car: 2011 G37 Coupe
Yes your overall diameter is smaller; you are now making more revolutions per mile, which will make your speedometer read faster then you are actually going and your odometer is now rolling over more mile than you are actually going too.
T00Ezy
no wonder why everything feels like its going up so fast lol.. i gotta get the correct conversion then. 235/45/18 is the exact right?
BRicci
Should just stay within about 3% of stock, but that's the stock tire size so it's perfect.
T00Ezy
alright good thing i didn't get my tires yet.. i gotta change my order to 235/45/18's tmrw then i don't think itll cost that much
BamaCoupe
Car: 2011 G37 Coupe
Like Bricci said, but my personal preference is if your 3% off it's better to be off on the high side so that your odometer roll over slower rather then the other way around like you are now.
