whiterps13 wrote:Im getting really tired of everyone on this forum thinking that staggering wheels/tires is THE answer to all of their problems. Its not just you.
Staggering is extremely unnecesary when you can run 9 inch wide wheels on the front of an s13. There is no need to run anything wider in the rear unless its a drag only car.
If youre going to be running auto-x and track events, staggering is only going to exagerate the underrsteer that your 17 year old car has. Plus, you cant rotate youre tires, which is very important in tight auto-x courses in terms of tire wear and longevity. Plus, a 10 inch wheel in the rear isnt going to give you any more grip than a a given tire on a 9 inch wheel.
Run a 17x9 +20 with 235/40/17 all the way around. Its by far the best setup for an s13 without major fitment work.
Not true on the stagger comment... I have an extreme setup only due to the cage... but with a VLSD, Kei Office XT's, cage, stock Hicas sways (Hicas is gone of course), and 235 on a 17x9F/245 on a 17x9.5R... mine has very little trouble with natural oversteer (not entirely throttle induced) which is why I've considered upping to a 20mm stagger over the current 10mm (along with larger sizes... these were free tires). On the stock 205's and no cage with everything else the same... she was still bias toward oversteer.
Best mod you can do to a hatch is a cage btw... I'm dumping my door bars soon b/c I'm turning the car from race into a "GT" car... but 4-6pt is a must if you have a hatch (just make sure you have padding as you don't wear a helmet on the street... normally)... saved my life (no lie) in a Z33 too... but that's a tangent
My AP2 S2k would be dangerous if it wasn't staggered... some cars need it, and since not all modded S13's are the same... each owner should assess the need for tire sizes based on their driving style/purpose for the car (including future mods since wheels can be a huge investment).
Lots of people are out for image (not big on that for this kind of car, but whatever... their car isn't mine)... but staggering can even work the ones that aren't if their mod setup demands... so it's not fair to say running a square setup is the way
Just my $1.50
But... 17x8 and 17x10 isn't worth it... unless you do drive a S2000 (man that car sucks for wheel choices btw... my stocks are 17x7.5 +55 and 17x8.5 +65... +65!!!)... put a 9 in the front if you're doing more than 9 in the back for sure
Modified by rbsileighty at 8:27 PM 2/11/2008
