DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Tue Aug 16, 2005 4:36 pm
absolutely true, devious always knows. but both of you folks are too hard headed to admit the other is sorta right.
I have a 248 intake and 232 exhaust, an s13 and an s14, the lobe placement is identical to the other post. Identical to my first S13, my second S13 and my 2 S14 motors, its a damn good representation, plus when you install the cams its only natural to get that little bit of slack. Its good practice to rotate the motor around as you say, or else you will hear it tightening when you start the car and its not a nice noise.
So you're both right. they point directly away from each other, but angled slightly up. and depending on if you have 232s 240s or 248s that angle changes slightly, but not enough to be off by one tooth.
I was a fool to ever run 248/248. 248/232 has almost identical topend, but the torque.... ahh.
