Need help with what the cams look like when first piston is at TDC
s13drft89
Car: 1991 Twin Turbo 300zx & 1968 Mercury Cougar
MarkEmark
Car: fully-built '95 240sx KA-T
s13drft89 wrote:Need help with what the cams look like when first piston is at TDC
The pointy ends of the four lobes will all be facing outwards (toward the fender of the car)...TDC on #1 means both intake and both exhaust valves are closed, so the lobes on the cams will be pushing down on the shims the least at this point, hence the reason the pointy ends are all pointing outward.
Here's what mine looked like.
Hope that helps
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
or you can just look at the cam sprockets. on the intake cam the mark on it should be pointing towards around 11 o clock, and the exhuast cam should be pointing towards around 1-2 o'clock.
when i was trying to line up my timing marks for the dizzy it wouldn't start at all, so i used the marks on the cam sprockets and my friend was urging me to use them and when i did, the car started on the first try.
fabio420
Car: 1995 nissan 240sx se
Check this thread out:zerothread?id=130296
