evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jul 25, 2012 1:47 pm
ummm...parts store? dealer? nothing about a vg30et is rare or unusual
to do the swap it's easies to get a whole z31 trbo and swap over the motor crossmember and piping and ecu needed bits either complete or just convert your vg30e to an et (crossmember, ecu, injectors, turbo, oil pan, oil line, drivers side exhaust manifold, etc) I've picked up a couple of complete turbo parts cars for $500 or less
if you're asking about parts to service the vg30et you just get them where you get parts for your vg30e, just when looking the parts up you say turbo instead of non turbo
if you're asking about modding the motor it's all pretty much generic parts, boost controller, intercooler and pipe to fit, cone air filter, cat back or turbo back exhaust (certified muffler) this should get you in the 280 whp range, beyond that it gets a bit complicated, you have to do something to be able to tune, (romulaotor, piggyback stand alone etc), larger injectors, larger turbo and somwhere around 400 whp the pistons will need upgraded most people tend to stop short of forged internals but there are those that go for the gusto ultimately they can make about as much as the vg30dett but it cost a lot less to do it, they are much easier and cheaper to service and modify
