need help with water pump belt
mungee
Car: nissan 240
Hello, I need help with my water pump belt on my ka24de. I removed the old shredded one by removing the 4 10mm bolts holding the pulley. Now I can't put the new one on. Is there a tensioner I need to loosen inorder to put it on, if so which one is it? Your help is greatly appreciated. thanks
onosqv
Car: '92 240sx Vert
Think the water pump belt is connected to the power steering pump on the ka24de, which acts as the tensioner.
Try loosening the power steering pump pulley.
180fan
Car: 89 fastback
i thought the water pump belt was linked to the alternator. either way, follow the belt and it'll either be the alternator or the ps pump that'll need to be loosened to release the tension on that belt.
mungee
Car: nissan 240
the water pump belt goes directly down to the crank pulley, so should I loosen the alternator or power steering because both has their own belt to the crank.
irocknrol2
Car: 1991 240sx Hatch/1993 240sx Coupe
The belt is connected in line with the power steering pump. Put the pulley back on the water pump, then loosen the power steering pump and move it towards the engine to loosen and slide the belt on. Tighten the power steering pulley and tighten the bolts.
mungee
Car: nissan 240
Thanks everybody.
