Need help with water line to turbo.
JDMbyBlood
Car: 93 240sx Coupe
Maybe one of you guys can help me out. I picked up a Blacktop SR motor minus the turbo manifold and turbo, there were also no oil or water lines. I ordered the following oil/water line kit:
http://www.frsport.com/FR_Earl....html
The original hard lines had banjo fittings. I found where all lines hook up, but one. The line with the one that has a hose clamp on it. Anybody know where this line hooks up to?Thanks....
FSUDrifter
Car: trying to decide on one...
between teh head and the firewall. it's a ***** to get to with the engine in the car, but i've done it before. just make sure the screw for the hose clamp is facing up and spray some wd40 on the fitting and end of the hose and you should be able to slide it on there. the fitting faces the exhaust side of the engine
JDMbyBlood
Car: 93 240sx Coupe
Thanks for the reply.
