At least i manage this.
So first what i want to tell, that's there is one more way to fix this.
After you cut grey wire from vss, blue wire e-brake one you need to connect to other (black with gray marks) it's the 7-th (see pic) in the harness second row.
See the pics below
This is wire that need to be connected with e-brake wire. Remember it must be black with grey marks.
But do not cut this one!!!! Only connect e-brake wire to it. Remove insulation and connect them.
If it will be helpful for somebody, it will be nice )
