RAQ45t »
https://forums.nicoclub.com/raq45t-u36658.html
Sat Jan 28, 2006 12:13 am
Advising to check the mounts and possibly replace them is a very good idea for your problem.Sound and vibration travel in a driveline,however.You mentioned you just put 4 new tires on.Would the tire shop possibly allow you to put the car on their lift and check it? You'll need not only to look at the mounts for wear or cracks,but try and get a long rachet extension or other rod to place at your ear,and listen to the driveshaft,halfshafts,and even the differential for the noise/vibration you feel. Also keep in mind 4 new tires will balance well at times on a bent rim;most tire places don't spin the wheels to check for this;no time unless they are very good.I take my tires/wheels 20+ miles to a tire shop that checks EVERYTHING;they take 20 minutes a wheel and charge for it,but twice have found a bent rim I needed worked on.My turbo BMW had a vibration(previous owner) for a year until they found the bent rim that balanced on the tire machine WITH the tire on it.
Good luck...
