Need help with Vacuum lines for S14 Blacktop
taiyou
I need help with Vacuum lines for S14 Blacktop. Yes, I searched for like good 3-4 hours(Seriously) for 2 days, and I only see like million threads for S13 SR20I looked in the S14 FSM and in the manual, and it shows the vacuum lines from middle of the throttle body, but mine looks blocked with screws. I got it from a friend and I think he didn't do a good job.
Please help me out, and anyone with real pics would be greatly appreciated. That's all I need to do for it to run hopefully. I found 1 thread but even he didn't get it answered. I really did search for days and no luck, thus I'm posting it now.
180fan
Car: 89 fastback
pull out the screws. the one to the charcoal canister block off, the other two goes to the fpr and the bov. done.
somehow I don't see how one could have failed at pulling up the vac diagrams. one could have looked for vac or vacuum in conjunction with sr or sr20 or sr20de or sr20det and have found the answer fairly readily or worst case scenario turn on the "search the archives".
It's not rocket science, if you don't pull up what you need, broaden your key words, if you pull up too much make it more specific.
taiyou
I screwed up with the post. The screws I'm talking about is in the middle of the intake manifold. I don't see anything on the TB.If you can find the vacuum line pics for the S14 SR20, please give me the link, I'm not a genius like you. thanks
squirrl22
Car: 1995 s14 with s14sr20det(blacktop) and manual transmission swap, 3 inch ss exaust, stock intake incl
I've got the same problem. we've got the s14 blacktop installed in our 95 240sx, and I have 4 vacuum lines that are just hanging. we've plugged the vacuum lines w screws, I wish I knew which one went where. I am pretty sure 2 of them go to the carbon canister, but which ones? One of the lines comes from the FPR, but what does it go to? -on previous threds abt an 18, this line went to a BOV. I don't have a BOV, should I add one? If I can get a response from anyone, I'd be happy to post some photos so you can see exactly what I'm looking at. tx!
BoBa524
Car: 1995 Nissan 240SX SE
let me know if these help, i can take some pics of my vacuum lines for you if you want cuz i'm running a completely stock s14 sr.
