It's cool, I wasn't taking a chance to attack you; everyone's pretty much here to gather research, socialize, and ask questions when need be, so it's not a problem. I just thought the other guy was being a d!ck since I was asking a pretty similar question with a similar setup as you --- I.E. What your goals on a "mostly stock" setup should be after a tune. I am tossing my **** together (ECU, new sensors, fixing my P/S, etc...) within the next few months and I will post up a dyno sheet / thread after my tune.BuH wrote:thanks again for the advice. i didnt know the greddy needy so much more with it. from what ive seen many make it sound like it was self sufficient. and to jonny. i by no way was calling u a "newb" i was stating im surprised that no body called me one by only have 3 posts now. btw nice as hell set up. nico is by far the best forum ive seen. plan on being here awhile
also ive recirculated the bov and its still having the issue. its currently recirculated with the stock bov now. one thing ive noticed different from my build than others is i didnt get a walboro 255 fuel pump. i got a r33 gtst pump and it was installed in the s13 tank. could that be an issue? when purchasing it. i had read a few write ups that said it worked, now im just questioning my work is all. trouble shooting is always fun and im glad i have experienced people to turn to.
understandable. It was pertinent to his thread (My first three statements) and his initial question, however -- I just added an extra one so he'd know what to expect after tuning on a mostly stock setup.Cjmartz2k wrote:LOL--settle down Johnny Butt. It looked to me like you did nothing more than post up your set up and ask how much hp you can expect to make. If you don't think so, fine, but don't get all rilled up about it.
Its common knowledge that the RB25DET maf maxes out pretty early, I would just go ahead and do the z32 maf right off the bat and get it over with. I can almost promise you will need to at some point anyway.johnny butt wrote:So on a stock RB25, is the Z32 MAF going to be required? I have one I can pick up if necessary, but I don't feel like shelling out more $$ when I am picking up an "RB25 Apexi PFC" designed (and discontinued) for the RB25.
Or are you using the Z32 MAFS just for better airflow readings?
A single RB20/25 MAF is good for something like 300-350rwhp, and a Z32 MAF is good for around 500rwhp. Those numbers are just how much air it can measure before it maxes out at 5v. I ran out of flow on the Z32 a while ago. A Power FC gives you the option to simply select which MAF you are using (including a Q45 MAF).johnny butt wrote:So on a stock RB25, is the Z32 MAF going to be required? I have one I can pick up if necessary, but I don't feel like shelling out more $$ when I am picking up an "RB25 Apexi PFC" designed (and discontinued) for the RB25.
if you're running the r33 pump you should run an adj. fuel pressure reg. to make sure your fuel pressure is stock. if not it could be rich, and causing it to stall.BuH wrote:
damn, didnt know that about the stock rb25 mafs.... looks like to hit 400whp i need to get a new maf too... damn money pitCjmartz2k wrote:A single RB20/25 MAF is good for something like 300-350rwhp, and a Z32 MAF is good for around 500rwhp. Those numbers are just how much air it can measure before it maxes out at 5v. I ran out of flow on the Z32 a while ago. A Power FC gives you the option to simply select which MAF you are using (including a Q45 MAF).
You don't need to use a "bigger" MAF right now (they are the same physical size) with a stock turbo, but you might as well since it's so easy to do with a power FC. I don't know if the tune would need re-checking if you went from a RB25 MAF to a Z32 and just told the PFC which meter you had. I guess it would be fine though.
