seang »
https://forums.nicoclub.com/seang-u122444.html
Fri Jun 11, 2010 2:00 pm
I forget whether this is on just the z24i, or the vg30i, too (their TBI units were out at the same time and only for a few years). I read about a problem where the two injector circuits bridge together on the wiring harness, . It is wierd because the injector wires come off the ECU as two circuits, then bridge together on the way there, and then split back apart into two before reaching the injectors. Where they bridge together, there can be some corrosion not unlike a corroded battery terminal, and this can make headaches. I forgot where I read that thread, though, but I think the owner was describing similar problems to yours. But, new gas first.
