Nav 4X4 »
https://forums.nicoclub.com/nav-4x4-u72162.html
Tue Aug 07, 2007 4:37 am
my ka24e was rattleing on start up as well, mines a genuine engine that has done about 140 k miles, I just finished puting a new kit through mine an hour ago, Im going to start it in about 12 hours time cause I want my silicone gaskets to dry a bit before I start it up.
Im hoping it will be quiet, because after about 20 hours of work one would want it to be, I to, did not use genuine bits, over here in australia, nissan wanted 575 dollars just for the parts, I found a reputable company/brand and bought the kit for 200 dollars. it all looked ok, the tensioner was made in japan.
Im sort of half expecting the rattle to still be there, because the original stuff I pulled out was still in pretty good nick, the chain only had about 1 mm of stretch in it, and the main guide wasnt too bad, it was only worn a bit.
In my quest for a quiet engine, I even considered manually stretching the spring thats in the tensioner, to try and give the new chain even more tension, but my mechanic bro advised against doing that, so I put everything in as standard. Anyway tomorrow I will know how good or bad it is,...wish myself luck !!
