Shocker »
https://forums.nicoclub.com/shocker-u18595.html
Sat Mar 17, 2007 7:11 am
don't use a ****ing ezy out, they break, and suck ***. Use a helicoli. They come in kits with the proper size you need for the thread. Basically if you don't know what it is. It comes with a tap/coils/inserter, then you buy the proper size drill bit that the kit requires.
You drill out the busted bolt, you then tap it with the provided tap, then insert your coil with the inserter, and screw in your new bolt for the tensioner..
Problem is you need to know the size and pitch of the bolt to get the kit. I did this with a broken cam retainer bolt.. and now about to do it with exhaust studs, worked amazing with the retainer
Now you might get buy with an ezy out... but I dont have that luck.
