Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Fri Apr 22, 2005 2:11 pm
I replaced all the boots on my friend's 1993 J30. The fronts are a little bit harder than the rears. You have to remove the strut and hub assembly in one piece. The strut is an insert. You open the original one, clean out the fluid, and insert the new one. Give yourself about 6 hours to do all 4. It took me 4 hours to replace the boots and the steering rack boots. I would think maybe 2 more hours, to completely remove the fluid and clean the housings.
