jjewell21 »
https://forums.nicoclub.com/jjewell21-u198883.html
Fri Feb 17, 2012 8:10 pm
Ok so I need help to figure out what I should do next here's my setup ,
Sr20det black top Turbo - gt2876r - walbro 255 - z32 maf stock 370 injectors bored to 550's so I'm told - 1.1 mm metal head gasket - arp head bolts - adjustable waste gate - boost gauge in car - aftermarket light weight pulleys - safc-1 not installed - car has redline performance pre tuned ecu, ecu is tuned for 740 injectors , z32 maf , and I believe 17 lbs of boost to make a rwhp of 450 . My question is , what should I do to the car , should I leave the pretuned ECU in the car and install a air fuel ratio gauge and the safc and upgrade my injectors to 740's like it said and then go have the safc and car tuned? Or should I buy a stock ecu, airfuel gauge and maybe upgrade to 550's and sale the safc and go get the car tuned and be done with it? As it sits right now , the car was tuned by turbo Dave in atl, at 17lbs at 300rwhp, and they had the fuel pressure regulator turned way Down so it wouldn't fluid the car out at high boost, since it has the pertuned ecu for 740's. I just bought the car and need help with what I should do to have a safe daily driving car, I figure just get 740's and install safc and have it dyno and the safc tuned and it would be fine , but my dad and his 240 buddy seem to think I might have problems if I keep putting money into the car without knowing what I should do . I know the pretuned ecu probley wont hit the number it says it will but I'm on a tight budget and need to get people who no about these cars to help me figure out what to do , I was told the car is running a bit rich cause they couldn't turn fuel down anymore but I haven't installed a air fuel ratio gauge yet so I dont no if its rich or just right or leaning out . Help plz
