need help with Sr power interface!
johnnys180sx
Car: 240sx
OK SO TODAY I FINISH MY FIRST SR Swap and when i start it, i got fuel but no spark. but i think I'm not getting power to the igniter chip, i did the wiring myself and when i look at frsport.com way of doing it, there a black/red wire tat connects to a black/red but on Sr side your supposed to connect a blue/red too? but on my hardness there 2 blue/red wire a big one and a small one has any body had this problem?
Emperor_Tha
connect the blue/red with the black /red
johnnys180sx
Car: 240sx
ok but whic one there are two blue/red a big one and and a little one i will soon take pics
Emperor_Tha
the big one iirc.
johnnys180sx
Car: 240sx
ok i going to try it
johnnys180sx
Car: 240sx
hey it run wow!!! that cool thanks bro but look run ruff and when i diconncet the maf it runs good at idle?what u think i should do? i'm getting 12v to it
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
go drive it around, it might be an idle thing. see if it still stutters
duffman1278
Car: 89 240sx Hatch, the wildcats!
Its an issue with your MAF, based off of what you discribed. Either clean it with MAF cleaner!!!! Not brake cleaner or CARB cleaner. If that doesn't work, I'd look into buying a used working one.
johnnys180sx
Car: 240sx
yeah i have a buddy test out maf he said good that i may have a vacuum leak some were now the only place i think i got vacuum is by the tps and were the brake booster connect is there any were else the u get vacuum?
