spec-v5150 wrote:Yeah you just kinda confirmed whaT I was thinking. I noticed that the wires for the lights and what not go towards the car. So I just need to remove the harness ON the motor??? I read somemore after I posted this and thought the same thing. I have everything. Full harness, gauge cluster, ECU, power steering lines, etc.
Yup all you need is the dohc wireharness, ecu, coil, ign chip, gauge cluster and ps stuff. Its a straight bolt in job. Only problem you will encounter is the dash plug by the ecu. The dohc harness has fewer wires than the sohc plug. But its basically a match up and repin game.
