need help with shift knob nad some extra questions
vocoder
how can i remove shift knob on my j30t 94and can someone post pics how can i remove wood mask withoud braking it. (where is A/C, Bose )
and my cigar lighter dont work? i checked the fuses, its all OK
my low fuel indicator isnt working? what could be the problem?
and anybody knows where can i find rubber (trim) for the sun roof
thank you
Modified by vocoder at 7:47 AM 6/26/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The button for the shift knob snaps in place.. You remove the button by gently prying the tabs and it will come right out.. Then you use a deep socket, i think its 10mm and remove it. pretty easy...
The low fuel indicator comes on when theres less than 4 gallons in the tank..... its just a switch on the fuel sending unit in the tank, could be the problem as well, but havent heard of them failing.
Are you referring to the gasket for the sunroof?
yodawill2000
Car: 94 Infiniti J30
low fuel indicator ?LOLGuess mine is out too ,Never have seen it and have run it on vapors a few times .
vocoder
elwesso wrote:Are you referring to the gasket for the sunroof?
yep
and reason why am i removing shift knob is because now i can change gears withoud my key in it. so if you have any picture of showing how to fix that problem i would appreciate
J30tman
yodawill2000 wrote:low fuel indicator ?LOLGuess mine is out too ,Never have seen it and have run it on vapors a few times .
Same here. I have never seen a low fuel light on mine either.
vocoder
J30tman wrote:Same here. I have never seen a low fuel light on mine either.
J30tman
I guess I don't have a problem... I just havn't seen a low fuel light on my j30 and I have had it below the very last mark on the gauge.
mossberg115
I also had never seen my light but I changed all fuses in the fuse baox and...BAMM.. It comes on as soon as I hit "E" ...I get about 5 miles from that point
Defiant
Car: 1997 J30
My low-fuel comes on right about 300 miles, and if I can lift just a little I get right around 20mpg. Some day I'll actually load up a can and go find how far I have left.The shift knob's pushbutton has two tangs, one left and one right. You need something like pen-knife blades to reach down along the sides and gently get them to release and lift off the button.Do a search for "shift lock" to get hints about the no-key shiftability.
