need help with setreo deck
240sx_in_209
Car: 89 240sx.... 93 coupe
hey well im installing a sony stereo deck that i got..... well my problems are that its not getting power. Its only getting power from the always on power cable, but not the ignition power, and it keeps blowing out my fuse in the kick panel for the radio any help?
cavepiggy623
Car: 1990 240sx coupe 2000 Altima
sounds like you have a short to ground in your acc wire. that will cause the fuse to blow.
Broadfield
Car: 1992 240sx
Does it blow the fuse if you have the Sony radio unplugged?
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
i just installed a new deck yesterday.
make sure you are getting power from the +12 volt accessory wire (BLUE)
this is the main power input to the unit. it is active only when the ignition is in the ACC or ON position.
240sx_in_209
well i dont know what happen but it started working again... i took out the fuse put another one back in and it worked acc power on.. i didnt do much it just started working so dont really know what the problem was
Witness
Car: 1997 240sx SE
very off topicbut i see your in pattersonyou ever in merced?
240sx_in_209
hm.... not really just once in a while when i go to the pick n pull there
