Need Help with SD Card Map Update
General discussion area for the L33-chassis Altima.
jimhadar
Car: 2013 Nissan Altima 3.5 SL
I have a 2013 Nissan Altima with Navigation. I currently have the 2015 maps installed in my car. I just purchased the 2018 map update. When I insert the new SD card, the card is recognized as a Nissan Card but I am not prompted to perform the update. Has any of you experienced this issue? Any tricks you could share to coax the car to detect the new version of the map and perform the update?
Thanks.
Reason: Delete duplicate post
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Welcome to NICO!
Just a friendly FYI: Cross-posting (i.e. posting the same message in more than one forum board) is frowned upon. It's confusing and often counterproductive. Please choose the forum topic that is closest to your post, and place it there only. If you should create a post in one forum, and later realize it would be more appropriate in another forum, please delete the original before posting it again.
Now then, do you have the coupe or the sedan? The 2013 COUPE nav system is updated by DVD, Part number U4513-0070-710NAM.
The 2013 SEDAN nav system is updated by SD card, Part number U4416-0080-710NAM. You cannot update the coupe nav system with the SD card.
http://nissan.navigation.com/home/en_US ... NIS-NAVCOM
Return to “5th Generation Altima Sedan (2013-2018)”
