Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Dec 23, 2007 6:13 am
Final drive ratio coming out of the trans should be different as 6th gear shouldn't be the same as a 5-speed's 5th gear. Either or, you have to get a converter for the speed sensor. I can't remember who makes one, but you can email the guys at Heavy Throttle. They should know.
Since the speed sensor takes incoming revolutions from the input shaft, you can change your rear diff with no hassle. But to maintain original ratios, you should reuse the S15 final drive.
Last S15 front clip I saw came with the diff, but no subframe. If someone is trying to sell you a front clip with no diff in it, tell them they have no sale until there's a diff. There's no point in paying that much money to be missing something so vital.
As far as differences and swap procedures, I'm just gonna tell you to search. Also, check out the SR FAQ in the RWD SR section.
