Raine »
https://forums.nicoclub.com/raine-u38220.html
Sat Mar 18, 2006 5:14 pm
The high beams are probably the same connectors (Halogen bulbs). The low beams on the S15 headlights are projectors. You need a HID kit for the low beams. You can probably take an X-Acto knife and cut the bulb casing so it fits into the headlight housing or something to that extent.
P.S. Did you cut a hole in your radiator bracket to fit the headlights, or you just buy new brackets? Also, can you tell me where you got the fenders, bumper, and lights for the conversion?
