Need help with S14 turbo oil drain gasket.
masamunex03
Car: nor is this
Hey, I was wondering if anyone out there knew of a direct replacement for an S14 turbo oil drain gasket? A friend of mine purchased a S14 t28 turbo from a local 240 guy and he didn't get the oil drain tube. Since I cannot find an S14 oil drain tube I was going to try to modify the stock T25 oil drain tube so that it will work with the T28. Since the bolts do not line up correctly I was just going to get a gasket to use as a reference of how much of the metal I would have to remove so that it would fit correctly. So does anyone know of a gasket that is a direct replacement or does anyone have one off that is off the car that they would they be willing to scan and post? Thanks in advance.
masamunex03
Car: nor is this
Someone please help!
bruinbear714
S14 oil drain tube
There ya go.
masamunex03 wrote:Hey, I was wondering if anyone out there knew of a direct replacement for an S14 turbo oil drain gasket? A friend of mine purchased a S14 t28 turbo from a local 240 guy and he didn't get the oil drain tube. Since I cannot find an S14 oil drain tube I was going to try to modify the stock T25 oil drain tube so that it will work with the T28. Since the bolts do not line up correctly I was just going to get a gasket to use as a reference of how much of the metal I would have to remove so that it would fit correctly. So does anyone know of a gasket that is a direct replacement or does anyone have one off that is off the car that they would they be willing to scan and post? Thanks in advance.
CMG
Car: 1989 240sx Hatch w/ Redtop
Anyone know the part number for the S14 T28 oil drain gasket? I was hoping to get one from the local dealer.
blk180sx
15196-79E00
