Darius wrote:It sounds like it doesn't have the ignition wired up properly. If there's no power signal from the key switch, there isn't likely to be power to the ECU either so of course it won't run. Verify the ignition switch wiring first.
i have already checked the ignition switch. there is power going in, power going out when in acc and on, power going out when you turn to the momentary spot. we also checked the ecu for i dont remember the pins but they were starter signal and ignition signal. and they were both getting power. and the right voltage. where would i check after that? i mean this car started fine like 3 weeks ago... we didnt mess with any of the wiring while we did the engine swap. HELP
