Need help with rims
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Cheatermouse
Car: 2007 Nissan Versa Sedan
Good day everyone! I'm new to the forum and also a newbie with cars. I want to learn all this and that about cars and I want to start with the rims. I want to change the rims of my 2007 Nissan versa (sedan), but I don't know if 17" will work in my car. Here's the 2 choices I'm thinking of:
1.http://www.wheelfire.com/scontent/Wheel ... n=STANDARD
2.http://www.wheelfire.com/scontent/Wheel ... n=STANDARD
Any help will be much appreciated and I'm hoping to learn from everyone :)
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
both of those would look good. 17" x 7" (or 7.5") fit great on the Versa. Just make sure the offset if not greater than +42, but those you linked to should be OK.
BTW, welcome to the forums.
Cheatermouse
Thanks for the reply, btw I don't need to do anything on my springs right? the factory installed should be fine? I saw alot of cuztomized versa with 17" with rigged springs.
Atx_Versa
Car: 2008 Nissa Versa SL
Cheatermouse wrote:Thanks for the reply, btw I don't need to do anything on my springs right? the factory installed should be fine? I saw alot of cuztomized versa with 17" with rigged springs.
If you go with the aftermarket wheels it just looks and performs better if you install a set of lowering springs. Otherwise it just doesn't look right (to me anyways).
Cheatermouse
Any estimate how much it will cost you over all if you lower the versa?
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
do you have any tools to do the work yourself? There are some good sets on the For Sale thread for ~ $130 + shipping. We have a tutorial video on doing the work.
Cheatermouse
No I don't, and now i'm thinking twice because read alot of people are having a problem with a lowered versa.
Cheatermouse
I forgot to ask what is offset?
kvg
Car: '08 Nissan Versa Sport
'89 BMW 325i coupe
Cheatermouse wrote:I forgot to ask what is offset?
what look do you want?
Cheatermouse
kvg
'89 BMW 325i coupe
that wheel has no offset options
Cheatermouse
I did some research about the offset and found out that the offset of this wheel (17x7) is 40 according to this websites:
http://www.buywheelstoday.com/products/ ... ipe%29.bwt
http://www.nlmotoring.com/XXR-519-Wheels-s/1526.htm
kvg
'89 BMW 325i coupe
that will fit no problem.
Nobodysful
Car: 1989 nissan 240sx coupe
my name is Frankie and i work in a tire shop that specializes in the purchase and installation of aftermarket wheels, i have an app on my work computer that can tell
me wether or not the wheels would fit ur offset, boltpattern, wat size hub rings and
even wat size tire to use so that u can stay as close to the factory rolling diameter as possible, my work number (203) 847-0345 ask for frankie and have ur car info and wheel info handy and i can give u an idea of wether or not they will fit, if they wont fit i can def point u in the direction of similar wheels that will fit.
mon-fri 8am-6pm sat 8am-4pm. holla at me if u need help
Return to “Versa Technical Discussions”
