Need help with rims !
All things Altima Coupe.
natalia3689
Car: 2009 Nissan Altima Coupe 2.5s White
First, I know there is an entire thread "what will fit my car" and I read through it all... I just want to verify with everyone's knowledge that the rims I want will fit!
First they are to die for! They are five axis ad s5.. 19x8.5 offset 3019x10.5 offset 33245-35-19
I know the offset is pushin the limit but from what I read they will fit..Please just a quick response before I purchase! thank you thank you
mcheddadi
Car: R8
will fit, front will be tight
natalia3689
thanks a bunch.
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
will fit, you'll be super flush. i'm on nearly the same setup, i have 19x8.5 +30 front, and 19x9.5 +33 rear. are you planning on putting 245/35 tires on both front and back? it might cause a difference in height of your tires
natalia3689
the front tires are 245/35. what tires should I be puttin on the back then?
Blackmobile
sorry i always forget what my rims are, i'm actually on 19x8.0 and 19x8.5, but my offsets are right. i'm just looking at a tire calculator right now and it's saying that the smallest tire you want to go with for a 10.5" rim is 275. you might want to look into your tire sizes a little more, use this: http://www.wheelsmaster.com/rt_specs.jsp
looks like the perfect match is 245/35 fronts and 285/30 rears, but those are huuge rears
Modified by Blackmobile at 1:02 PM 11/5/2009
natalia3689
oh noo!! i want these rims sooo bad and hes sellin em at a good price.. do you think its a no go?
