jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Fri Mar 24, 2006 1:28 pm
DISCONNECT THE BATTERY FIRST.
remove the two motor mount nuts/bolts (both 14mm). both are located under the intake and exhaust manifolds. then remove the 4 transmission bolts that mount the transmission to the chassis. also, remove the slave cylinder at the right side of the transmission (passenger side). remove the radiator and shroud. remove driveshaft, and remove shifter from inside the car (held down by a snap ring)
remove entire wiring harness. just whatever clips that connect to the engine, remove them. same goes for AC and all the hydraulic lines (like power steering and stuff).
drain all the fluids, wrap the chain evenly around the intake and exhaust manifolds without pinching any wires and hose (especially fuel lines) and then slowly lift the engine up. a good tip is to lift one lift at a time, then pull back twice. if u have a friend have him get under there and guide the transmission.
BAM ur done. if u do this many times, ull get the engine out by yourself in less than half an hour. its really easy. and if u have a friend, itll take damn near half the time. really simple stuff!
