Need Help With Rear Suspension Arms
britter
Car: 1991 Nissan 240sx
Ok so i have a 1991 240sx that I am needing help with. i took all the arms off the subframe replaced all the bushing with prothane ones and put it back together. I went to get it aligned and aperently i didnt put the bolts back in the right place. From what they were saying is that the bolts with the washers are to go on the rear lower arm and the camber arm. Is this correct? Also I have tried to find a picture to verify this and that they are going the right direction but this is all that i could find. But it does not show any washers? Please help me out and thank you in advanced for your input....
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
The bolts that have a groove for the washer need to go on the inside upper control arm and inside toe arm so you can adjust camber and toe
britter
Just to verify you are talking about these two correct?
compactfean
daily
Yes excactly.
britter
THANK YOU VERY MUCH!!!!
