Need help with re-initializing OBD-scan tech on laptop.
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
My drive crashed on my laptop and so I had to re-initialize OBD-scantech after reinstalling Windows. The problem is that it will recognize what port I'm on but when I go to the live data section, all I get is N/A and then I get an error. I can't remember what it is. I have the ECU talk usb cable and I'm running Windows XP sp3. I can run ECU talk version 1.3.5 (I think) fine so I know the cable is good and my computer can talk with the ECU.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Do you have a screen capture picture you can share? Or call me up.
mattd1979
I ended up uninstalling and re-installing obdscantech and copied the 3 files for version 1.51 to the scantech directory and ran it. It will now run but when I select power balance, I get the following error....
run-time error '339':
Component 'RICHTX32.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
mattd1979
Anybody have any ideas about the error code above? I installed it per the directions.
mattd1979
Well.... No one had an answer so I did some more digging and found the answer. Here is a link for those who may find themselves in the same predicament as I was in. Follow the directions and you should be set.
Matt
http://www.winhelponline.com/blog/fix-f ... a-program/
