1. Vac line at end of balance tube:
Can I use this as a boost gauge source?
2. I think r32 rb26's only have 1 brake boost vac hard-line but on my motor there are 2. Is this right? I know my brake booster rubber line goes into one of these ports but what do I do with the other? Can i just cap it off?
3. I have this rubber hose coming out of hard line from my fuel tank. My 98' 240sx didn't come with an EVAP canister and I believe this is for getting rid of atmospheric fuel smell. Would it be okay to just let this vent out?
4. There are 2 rubber lines on the front of the motor that I know go to a skyline EVAP canister, but since I'm not using it, can I just cap these 2 ports off as well?
5. Lastly, by looking at Tyndago's vacuum diagram, the green & blue rubber hoses that connect to the stock boost solenoid on the passenger side. Can I just those 2 ports for an aftermarket boost controller? I believe so.
Thanks!
