blues14 »
https://forums.nicoclub.com/blues14-u27988.html
Sun Jun 12, 2005 1:34 pm
Ok, heres the deal. I have an s14 rb20det 5spd. the car runs perfect up to 5k rpm, and the the power curve just dies. The boost gauge stays at 10psi, I just installed a new z32 fuel filter, and the car has a walbro 255 fuel pump that was installed at the time of the swap. (i never saw it so hopefully its in there) I am on the auto ecu (i swapped from auto to manual) and i thought that was my problem, but i just got done using my friends MINES mt ecu and although power improved up to 5k rpm, it still had the high end problem. I used the ecu diagnosis and it gave code 55- all ok and then i did the O2 ecu test and it blinked once, which i believe indicates lean. Could one of the coils be missing at High rpm? could the walbro be giving me trouble? maybe timing? How should I go About diagnosing this problem?
