Sil240 wrote:the thicker the HG the LOWER your CR is going to be.
The lower your CR is the worse off boost power is going to be, plus booost will take longer to kick in.
Depending on how much the head/block were decked...
You would need stronger springs if you upped your lift... I'm not going to say if you will float due to revs, but I will let you know when my 270's go in my motor that have a little more lift than you were looking at 8.8mm lift (Tomei Pro non lash type still sitting on the shelf waiting for my motor to be pulled to do some other work on it... which is waiting on me to finish the drywall in my garage... anyway)
