Need Help With Purchasing A Smoker
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
So for the last few years I've been using cast iron smoker boxes for smoking ribs and steaks on my propane grill. I was at home depot the other day and saw smokers for what I consider to be cheap. So what will best suit my needs? Why would someone get a gas or electric one? Is it only if they want to use it as a grill as well? Do you use use coals and place the wood chips on top? any help and tips are greatly appreciated.
EDIT: Here's 2 I was looking at. Both priced @ $65.00
Klits562
Car: white s13 coupe
Empty V wrote:So for the last few years I've been using cast iron smoker boxes for smoking ribs and steaks on my propane grill. I was at home depot the other day and saw smokers for what I consider to be cheap. So what will best suit my needs? Why would someone get a gas or electric one? Is it only if they want to use it as a grill as well? Do you use use coals and place the wood chips on top? any help and tips are greatly appreciated.
my dad has a smoker and man i tell you the food he makes in that thing is GODLY!!!!
Im not exactly sure how they work they might just work off gas or coal and you through the woodchips in for the flavor.
Just ask someone at the store thats selling them im sure they know how they work....atleast i would hope
Empty V
Klits562 wrote:my dad has a smoker and man i tell you the food he makes in that thing is GODLY!!!!
I'm planning on buying it from home depot in so-cal. First it's home depot, 2nd not a lot of people (at least that I know of) smoke food out here so getting good info is going to be tough.
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
I think Beancooker should probably go for cheap... where is that bastard?
s0m3th1ngAZ
Car: 96' Miata
2014 Focus ST
We've used a cheap aluminum one for years to smoke fishies. Looks like it came from the 70's.
This thread is relevant to my interests. Tuning in.
bcar240
Car: 1993 240SX HB
My roommate has an electric one and it works fine for slow cooking ribs and the like. But it will not get very much hotter than his rib cooking temp even though its thermometer goes several hundred degrees higher, so there are a couple recipes that he has hesitated to cook with it because he is not sure if it is getting hot enough. That red one looks much better than his though, the one he got looks like a few pieces of sheet metal riveted together with a coil at the bottom.
Empty V
bcar240 wrote:My roommate has an electric one and it works fine for slow cooking ribs and the like. But it will not get very much hotter than his rib cooking temp even though its thermometer goes several hundred degrees higher, so there are a couple recipes that he has hesitated to cook with it because he is not sure if it is getting hot enough. That red one looks much better than his though, the one he got looks like a few pieces of sheet metal riveted together with a coil at the bottom.
So do the electric one's just heat the wood chips with a coil? Do you know how it works?
Thanks!
Pwnin O'Brien
My dad smokes turkey for thanksgiving and whatnot. He uses a charcoal smoker and it works surprisingly well. The only problem is that you have to constantly monitor the temperature gauge on the charcoal smoker. I think he uses the flavored wood chips and it makes the turkey taste really good.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
I have the red one ,it works great.You put the wood chips in the bowl with your water.You can also remove the heating element and put charcoal in the bowl and use it as a regular grill.
Empty V
sx moneypit wrote:I have the red one ,it works great.You put the wood chips in the bowl with your water.You can also remove the heating element and put charcoal in the bowl and use it as a regular grill.
Nice! So how do you use the water?
[EDIT] I soak the chips in the cast iron boxes for 30min then drain and throw on the grill.
Empty V
Pwnin O'Brien wrote:My dad smokes turkey for thanksgiving and whatnot. He uses a charcoal smoker and it works surprisingly well. The only problem is that you have to constantly monitor the temperature gauge on the charcoal smoker. I think he uses the flavored wood chips and it makes the turkey taste really good.
I think I might be trying to accomplish the same thing. It sounds like a lot of work.
Empty V
Bump, where's our knowledgeable smokers (food) at?
themadscientist
I think you can get him cheap.
sx moneypit
1986 Toyota MR2
Get the electric one ,you won't have to worry monitoring the temperature.There are lava rocks that you set around the heating element,that is where you put the wood chips.The water bowl sets above that to collect the juices and help keep whatever you are cooking moist.
