Need help with power steering pump..
sr20-thoj
Car: 89 nissan 240sx coupe
I have a 93 fastback w/hicas.. I just swapped out the motor with another ka24de. but this new motor doesnt have a hicas power steering pump.. its just a regular one.. any ideas?? i tried swapping them out but the mounts dont match up.. is there a way of making this work?
LayNLow240
Car: 92 240 coupe
How do the mounts not match up? there is no difference in the motor from hicas to se/base model. Swap pumps & brackets and you should be good to go.
sr20-thoj
they are almost the same.. mounts looks almost identical but the hicas mount is about 1/4 of an inch longer.. so basically 2 bolts towards the front fits but not the third one towards the rear..
reelyfast
fab time
